remote calendar read only
Hi I run thunderbird 115.5.0 (64bits) on linux 22.0.4 up to date and try to connect to a remote calendar on ovh's nextcloud 27.1.4 up to date following this link I get calendar's address https://plusjamaisca.ovh/index.php/apps/calendar/p/D6rJcrHYJJj9xxx near by name's calendar and it show up on thunderbird. However I can't create any event. This is the message : an error occured while writing in the agenda I get the same problem with windows 10 While I have 2 androids mobile working perfect and another linux 22.0.4 working well also
and does that calendar require authentication? read only usually means it does, and your settings do not include that.
Thank you for your answer OK then, I also tried with main caldav address that I use on my mobile. It looks like https://mysite/remote.php/dav which ask me for a password and I unfortunately get the message login details entered have not been accepted I' m pretty sure of my mail address and whatever thunderbird or nextcloud password I enter I get the error.
